Topic-icon [Occasion] Audi 80 quattro B2, 760Hp, 850Nm
porci82 a créé le sujet : [Occasion] Audi 80 quattro B2, 760Hp, 850Nm 18 Déc 2014 10:39 #48019
Une superbe auto à vendre :
Engine
2.5L I5 20VT from Transporter T4, 034 Motorsports Engine mounts, Hansen Motorsport custom rods, fully ported headers by EBB Flowtech, Hansen Motorsport header T4/Tial , Hansen Motorsport Precision 62/65 Turbo, Precision WG, Tial 50mm blow off valve, custom full 3.5? exhaust system, free flow or single muffler ( v-band ), Hansen Motorsport exhaust/intake cams, compression dropping head gasket, Turboxs boost controller, Hansen Motorsport light weight hydraulic lifters, Custom cam cover, ARP head and main bearing studs, 034 Motorsports EFI Stage II C fully sequential set-up,Aan pulley,VAG 60-2 trigger sensor, Custom wiring harness, 034 Motorsports injectors, 034 Motorsports high output coils, custom length plug wires, Innovate LC-1 wideband, Audi 1.8T inlet temp sensor, 034 Motorsports billet fuel rail, Aeromotive Eliminator fuel pump, Aeromotive 100 micron fuel filter, FuelAB high performance fuel pressure regulator, JAZ 10 gallon fuel cell, custom fuel cell bracket, custom battery bracket, custom wiring (mostly hidden inside chassis), custom intercooler, custom breather system, custom radiator, custom fan for radiator, custom oil cooler, custom fan for oil cooler, custom modified RS2 inlet manifold, custom intercooler plumbing, custom servo pump bracket, custom front engine mount, custom coolant rail, custom oil dipstick
Driveline
Sachs Racing clutch, Leanders Bros/Hansen Motorsport aluminum flywheel, custom transmission brackets to move transmission back 3?, 034 Motorsports Transmission mounts, stock Audi V8 CMG transmission, 034 Motorsports differential mounts, 034 Motorsports rear diff mount, Audi stock Audi S2 coupe rear diff, stock Audi RS2 driveshafts, stock Audi 80 Quattro rear driveshafts, 01E short shift, custom driveshaft, shortened 3?, custom shift linkage to accommodate moved transmission, custom carbon fiber exhaust shield for transmission, custom transmission oil cooler set-up
Suspension/Brakes
Custom front cross member, Audi Motorsport Group B uprights front and rear, Audi Motorsport Group B rear subframe with toe in/out parallel geometry, Audi Motorsport Group B front and rear control arms with bracing, Audi Motorsport Group B full spherical/heim joint chassis, Audi Motorsport Group B short steering rack, 1.8 turns lock to lock, Audi Motorsport Group B steering arms with spherical joints, Audi Motorsport Group B spindles with wheels studs, custom yellow polyurethane bushings for inner steering arms, Audi Rs brakes 8 pot 380 MM Front, custom brake brackets for Audi RS2 rear calipers, custom brake bells and discs front, custom brake booster from Audi V8, custom brake line system with bias control, Audi Motorsport Group B rear brake discs and bells
Wheels/Tyres
Custom painted OZ Rally 8J x 18? ET35 (Ford Transit White), Michelin 225/40-18
Exterior
Audi UR Quattro flared fenders modified, custom doors, Audi UR Quattro custom front bumper, Audi UR Quattro custom rear bumper, Audi 80 Quattro custom hood, Audi 90 Quattro trundled and rear panels, Audi UR Quattro side skirts, Audi V8 taillights modified, custom headlights, custom grills
Interior/Chassis
Full Audi Motorsport group B chassis spec, cut out inner fenders in engine bay, custom brace bars for front cross member, custom brace bar for suspension, top and lower, custom suspension towers raised 2? (lowering car and keeping travel), custom subframe to lower engine 2?, custom engine mount position to move engine rearwards 3?, custom exhaust system tunnel through firewall and under the car on passenger side, custom 16-point roll cage, custom double floor to protect from heat, custom Audi A3 dashboard with center console, custom RS2 instruments in A3 dashboard, custom modified Audi A3 steering column, custom modified Audi RS2 pedal box, custom hydraulic handbrake, OMP WRC composite seats x 2, OMP 6 point 4? seatbelts x 12, OMP steering wheel
Price :
For international buyers, the price is 37500 Euro call for more info +47 930 500 30.
The price on the listing HERE lists out at 339,000 Norwegian krone, which equates to about $46,000. Also, it’s worth noting that this car is old enough to qualify for importation as an antique… and that means it would be a relatively import to the USA.
liens :
fourtitude
silverquattro
speedhunters.com
ebbt.no
Phoenix912 a répondu au sujet : [Occasion] Audi 80 quattro B2, 760Hp, 850Nm 19 Déc 2014 06:56 #48038
Ben je suis pas spécialement attiré par les anciennes mais la j'avoue elle a vraiment de la gueule, pis les finitions et détails c'est un bijou
  • Remerciements reçus 110
audipassion a répondu au sujet : [Occasion] Audi 80 quattro B2, 760Hp, 850Nm 19 Déc 2014 07:30 #48039
un ZINC de compet !!!!
:oops: :woohoo:
  • Remerciements reçus 1162
Mikael a répondu au sujet : Re:[Occasion] Audi 80 quattro B2, 760Hp, 850Nm 19 Déc 2014 07:35 #48040
Elle est magnifique mais un peu trop cher pour moi... Ahah!
porci82 a répondu au sujet : Re:[Occasion] Audi 80 quattro B2, 760Hp, 850Nm 19 Déc 2014 09:00 #48044
elle est juste top!
et bien finie, même si j'aurais mis un autre Tableau de bord perso :lol: !
mais oui, elle chie des bulles :lol: !
Le prix est encore correct pour le job et la classe de l'auto!
