Encore une série après j'arrête ...
www.m5board.com/vbulletin/e39-m5-e52-z8-discussion/128129-secondary-air-system-carbon-build-up-removal-pictures.html
Cayenne Turbo 60000 KM
VW EOS
22000 KM
BMW 135i
70000 KM
Un peut de Bla Bla ...... j'en connais qui ne vont plus dormir ...
"Gasoline engines with direct injection of the fuel into the combustion chamber, i.e., not into the intake port, suffer especially from the problem of the formation of carbon deposits on components. Carbon deposits form especially in the neck region of intake valves. A more exact analysis of how these carbon deposits form leads to the following result: Oil and fuel constituents first form a sticky coating on the components. These constituents are chiefly long-chain and branched-chain hydrocarbons, i.e., the low-volatility components of oil and fuel. Aromatic compounds adhere especially well. This sticky base coating serves as a base for the deposition of soot particles. This results in a porous surface, in which oil and fuel particles in turn become embedded. This process is a circular process, by which the coating thickness of the carbon deposits continuously increases. Especially in the area of the intake valves, the deposits originate from blowby gases and from internal and external exhaust gas recirculation, and in this process, the blowby gasses and the recirculated exhaust gas come into direct contact with the intake valve.
Especially in the area of the neck of the intake valves, excessive carbon deposits have extremely negative effects for the following reasons: In the case of Otto direct injectors, the successful ignition of the stratified charge depends to a great extent on the correct development of the internal cylinder flow, which ensures reliable transport of the injected fuel to the spark plug to guarantee reliable ignition at the spark plug. However, a coating of carbon deposits in the neck region of the intake valve may interfere so strongly with the tumble flow that ignition failures may occur there as a result. Under certain circumstances, however, ignition failures can lead to irreversible damage of a catalytic converter installed in the exhaust gas tract for purifying the exhaust gas. Furthermore, the coating of carbon deposits in the neck region of the intake valve causes flow resistance, which can lead to significant performance losses due to insufficient cylinder filling, especially in the upper load and speed range of the internal combustion engine. In addition, the carbon deposits in the neck region of the intake valve may prevent correct valve closing, which leads to compression losses and thus sporadic ignition failures. This in turn could irreversibly damage the catalytic converter. There is the potential for small particles to break away from the coating of carbon deposits in the neck region of the intake valve and get into the catalytic converter. These hot particles may then cause secondary reaction and corresponding local damage of the catalytic converter. For example, a hole may be burned in the structure of the catalytic converter.
Globular deposits are found especially on the valve stem downstream from a partition plate in the intake port. Due to the dripping of high-boiling hydrocarbons from the partition plate towards the valve neck or valve stem, globular carbon deposits eventually form there by the sequence of events explained above. These deposits on the valve stem can result in flow deficits due to undesired swirling and turbulent flow around the globular carbon deposits. This may persistently interfere with the formation of stable tumble flow from cycle to cycle.
A possible solution would be to keep these sources of deposits away, for example, from the intake valve, by completely eliminating exhaust gas recirculation and the introduction of blowby gases into the intake port. However with the combustion behavior of modern reciprocating internal combustion engines, at least external exhaust gas recirculation and the introduction of blowby gases into the intake port are absolutely necessary for reasons of emission control and fuel consumption, so that this approach is not possible."
" Les moteurs à essence à injection directe de carburant dans la chambre de combustion , c'est à dire , non pas dans l'orifice d'admission , souffrent particulièrement du problème de la formation de dépôts de carbone sur les composants. Dépôts de carbone forment en particulier dans la région du cou des soupapes d'admission. A plus analyse précise de la façon dont ceux-ci forment des dépôts de carbone conduit au résultat suivant : huile et de carburant constituants forment d'abord un revêtement collant sur les composants Ces constituants sont principalement d'hydrocarbures à chaîne longue et à chaîne ramifiée , à savoir les composants à faible volatilité d'huile et . . composés aromatiques du carburant adhèrent particulièrement bien . Cet enduit de base collante sert de base pour le dépôt des particules de suie . Il en résulte une surface poreuse , dans laquelle les particules d'huile et de carburant , à son tour devenir noyés . Ce processus est un processus circulaire , par lequel l'épaisseur du revêtement des dépôts de carbone en continu augmente. Surtout dans le domaine des soupapes d'admission , les dépôts proviennent des gaz de carter et de recirculation interne et externe gaz d'échappement, et dans ce processus , les gaz de carter et le gaz d'échappement recyclés entrent en directe entrer en contact avec la soupape d'admission .
Surtout dans le domaine de la nuque des soupapes d'admission , les dépôts de carbone excessifs ont des effets extrêmement négatifs pour les raisons suivantes : Dans le cas d' Otto injecteurs directs , l'allumage réussi de la charge stratifiée dépend dans une large mesure sur le développement correct de l' écoulement cylindre intérieur , ce qui assure le transport fiable du carburant injecté à la bougie afin de garantir un allumage fiable de la bougie d'allumage . Toutefois , un revêtement de dépôts de carbone dans la région de col de la soupape d'admission peut intervenir si fortement avec l'écoulement sèche que les pannes d'allumage peut y avoir lieu à la suite . Dans certaines circonstances, cependant , un problème d'allumage peut entraîner des dommages irréversibles d'un convertisseur catalytique installé dans la conduite de gaz d' échappement pour purifier les gaz d'échappement . En outre, le revêtement de dépôts de carbone dans la région de col de la soupape d'admission provoque une résistance d'écoulement , ce qui peut conduire à des pertes de rendement importantes dues à un remplissage de cylindre insuffisante , en particulier dans la charge supérieure et la plage de vitesse du moteur à combustion interne . En outre, les dépôts de carbone de la région de col de la soupape d'admission peuvent empêcher la fermeture correcte de la vanne , ce qui conduit à des pertes de compression et les échecs d'allumage ainsi sporadiques . Ce tour pourrait endommager irréversiblement le convertisseur catalytique. Il existe un risque pour les petites particules de se détacher de la couche de dépôts de carbone dans la région de col de la soupape d'admission et de pénétrer dans le convertisseur catalytique . Ces particules chaudes peuvent alors provoquer des réactions secondaires et des dommages locale correspondante du convertisseur catalytique . Par exemple , un trou peut être brûlé dans la structure du pot catalytique .
Dépôts globulaires se trouvent en particulier sur la tige de valve en aval d'une plaque de séparation dans l'orifice d'admission . En raison de la goutte d'hydrocarbures haut point d'ébullition de la plaque de séparation vers le col de la vanne ou de la tige de valve, des dépôts de carbone globulaires forment finalement là par la séquence des événements expliquées ci-dessus . Ces dépôts sur la tige de valve peuvent entraîner des déficits d'écoulement dus à écoulement tourbillonnaire et turbulent indésirable autour des dépôts de carbone globulaires. Cela peut constamment interférer avec la formation de sèche- flow stable de cycle en cycle.
Une solution possible serait de garder ces sources de dépôts de suite, par exemple , à partir de la soupape d'admission , en éliminant complètement la recirculation des gaz d'échappement et l'introduction de gaz de carter dans l'orifice d'admission . Cependant, avec le comportement de combustion des moteurs alternatifs à combustion interne modernes , au moins recirculation des gaz d'échappement externe et l'introduction de gaz de carter dans l'orifice d'admission sont absolument nécessaires pour des raisons de contrôle des émissions et la consommation de carburant , de sorte que cette approche n'est pas possible " .
